15 years agoDSP builder IP generator error
Hi, I am using DSP builder 9.1, 10.0. I added the FFT mega core to my simulink model the regular IP generator GUI. When I double click it again, I rceive the following message in MATL...
14 years agoYes, I think you should try verifying that Quartus has included the".ipx" file in his serach path. I think it is generated under a folder called "IP". See in your Quartus project settings that it is pointing to that ipx file. If that does not work you should see if there are different versions of Quartus/IP, as mtjp answered in one of the previous answers
