15 years agoDSP builder IP generator error
Hi, I am using DSP builder 9.1, 10.0. I added the FFT mega core to my simulink model the regular IP generator GUI. When I double click it again, I rceive the following message in MATL...
14 years agoHi Ahmed,
I can tell you what was the problem with my appliation- I hope it will be relevant to yours. The altera IP generator creates different files. One of these files has the ".ipx" extension. If, for some reason, a Quartus project that uses the IP cannot find a file with that extension (.ipx) Quartus will give the following error message: (Error: IP Generator Error: Entity '' (Version latest) not found in librarian.) I personaly think this message is misleading, and I have spent quite some time before finding the answer. I wrote in my previous message that I think they should do something about this error message but appearently Altera does not feel the same (or nobody there knows about this problem). I can also say that I saw this error message when there was a difference between the two versions (for example: using Quartus 7.2 with IP core 6.1). It happend on and old version and I do not not if this still applies now. I hope I helped a little Godd luck, Gilad
