14 years agoDSP Builder IP generator Error - help please
Hi I am using DSP Builder 11. When I am trying to compile my design, the Quartus error I receive is: Error: IP Generator Error: Entity ' ' (Version latest) not found in librarian. I f...
14 years agoDo you use a imported Megacore or VHDL code? If this is the case run
alt_dspbuilder_refresh_HDLimport for imported VHDL code or alt_dspbuilder_refresh_megacore for imported Megacore in the Matlab command window to rebuild the dependencies for these blocks.
