15 years agodsp builder installation
i have purchased cyclone II DSP development kit EP2C70. there is an installation issue with DSP Builder v6.0 (dsp builder CD provided with the kit). i have install Quartus II version 6.0sp1 (pro...
15 years agoTo set the environment variable, do the following (assuming you're using Windows XP - Vista/Win7 are not much different):
1. Close Matlab if it's open 2. Left-click on the Start menu 3. Right-click on "My Computer" and select "Properties" 4. Select the "Advanced" tab and click "Environment Variables" 5. Click New below System variables 6. Enter Variable name as DSPBUILDER_ROOTDIR and Variable value as C:\altera\DSPBuilder\Altlib 7. Click OK and then OK again. 8. Now start MATLAB and the variable should be set. You can verify it's set by typing "getenv DSPBUILDER_ROOTDIR" at the matlab prompt.
