DSP Builder installation Problem
Hi
I'm trying to install DSP builder 7.0 but appears the next message "A matlab prior to version 7.0 has been detected on your machine. Operation with such a version is untested and therefore not recommended". I have Matlab R2007a and Quartus II web 7.0, why the message appears ? The last version of matlab (6.0) on my computer was uninstalled before install Matlab R2007a. Help me please.9 Replies
I do not think that version 7.0 has been tested with R2007a.
Hello, i have instaled the DSP builder v8.1 para Quartus II v 8.1 y MATLAB 2007a, all of then is instaled good, but when I start MATLAB and Simulink, only appears one library calls Altera DSP Builder Advance BlockSet and
allegedly DSP Builder has two libraries cals Altera DSP Builder Advance BlockSet and Altera DSP Builder BlockSet. would you help me whit this problemo or if you have the DSP builder v8.1 software, would you send it me please? - Altera_Forum
chema15, 2007a isn't supported until Quartus/DSP Builder 7.1. your error message doesn't reflect this problem, i wonder if all of the older files were removed.
http://www.altera.com/support/ip/dsp/ips-dsp-version.html - Altera_Forum
minoviohyde: so you can see/use only the Advanced Blockset blocks in the Simulink library browser?
can you type path into MATLAB and post the results? - Altera_Forum
In my simulink display appears the second picture and the correct installation is the first picture.
http://www.alteraforum.com/forum/C:\Users\yessica\Pictures\DSPinstal.jpg - Altera_Forum
I don't know if my picture si saw. - Altera_Forum
matlab 2007a,quartus 7.2sp3 and dspbuilder 7.2sp3 is the best
something wrong about license with my dsp builder 8.1 advanced blockset (http://www.alteraforum.com/forum/showthread.php?t=4199) ,anyone get the same problem ?
i think both blocksets use the same license line.
