8 years agoDsp builder error in matlab R2014a
I try to add dsp standard block from simulink library broser to simulink model file and I have an error in matlab command window:
Problem occured with mask object. DSP Builder cannot find the Java classes it needs to work. I can not save my simulink model file because i have an error. And i have no error when i add an advanced dsp block to simulink model file. )) What need to do to fix that?2 Replies
You are in the wrong forum for this. Try: https://www.mathworks.com/matlabcentral/answers/index?s_tid=mlc_an_ask
--- Quote Start --- You are in the wrong forum for this. Try: https://www.mathworks.com/matlabcentral/answers/index?s_tid=mlc_an_ask --- Quote End --- When installing DSP builder - https://alteraforum.com/forum/attachment.php?attachmentid=14803&stc=1 https://alteraforum.com/forum/attachment.php?attachmentid=14803&stc=1 an error occured. is it Matlab ?
