13 years agoDSP Builder Advances blockset sqrt block problem
Hello! I'm using DSP builder blockset and I have problem with SQRT prim block. I just cannot use two of this block! If I use more than one sqrt block in any subsystem (i tried to use it in one subsys...
13 years agoI didn't say they can't be in the same subsystem. I said they can't be in the "same primitive subsystem hierarchy". Essentially this is everything below the SynthesisInfo block.
The reason for this is that DSP Builder Advanced flattens all of the subsystems in this hierarchy before generating the HDL.
