13 years agoDSP Builder Advances blockset sqrt block problem
Hello! I'm using DSP builder blockset and I have problem with SQRT prim block. I just cannot use two of this block! If I use more than one sqrt block in any subsystem (i tried to use it in one subsys...
13 years ago --- Quote Start --- I can reproduce the problem. I don't think there's a work around unfortunately short of avoiding putting two sqrt blocks inside the same primitive subsystem hierarchy. --- Quote End --- Thank you for the reply! But they are in the different subsystems! Here is the example.
