16 years agoDSP Builder 9.2 and Matlab 2007b
If somebody is using dsp builder 9.1 and matlab 2007b please help me. I have problem because matlab can not see altera dsp builder basic blocks in simulink library. what i can do?
16 years agoThanks but what you think about this. It is information from Altera web side.
--- Quote Start --- DSP Builder 9.1 does not support MATLAB 2007b. You must upgrade to MATLAB R2008a or later. The installer for 9.1 should not detect MATLAB versions prior to R2008a, so if you ran it against this version then you must have manually set the path of MATLAB. After you install a newer version, you must then reinstall DSP Builder into the new version of MATLAB. --- Quote End ---
