17 years agoDSP Builder 8.0 Advanced Blockset / DSP resources
Has anyone been able to successfully specify that a given FIR filter / NCO / etc. be implemented with logic cells (instead of DSP blocks) in an advanced blockset design? From what I can tell, in the...
17 years agoYes if you can set the clock frequency to some integer multiple of the sample rate you should see number of DSPs drop appropriately. (be careful with valid/channel signals)
