17 years agoDSP Builder 8.0 Advanced Blockset / DSP resources
Has anyone been able to successfully specify that a given FIR filter / NCO / etc. be implemented with logic cells (instead of DSP blocks) in an advanced blockset design? From what I can tell, in the...
17 years agoI confirmed that they are in constant mode (which was what I intended). The other thing that I'm going to try is to over-clock the design (up to ~360mhz) to see if I can benefit at all from multicycle usage of the DSP blocks to reduce utilization.
