15 years agoDSP builder 10 installation in Ubuntu 10.10
Hi all,
My effort is try to install DSP builder 10 in Ubuntu 10.10 64bit. I have already search in this forum and google, but no guide can help me! First, I install Quartus 10, and Matlab 2009a 32bit. Everything runs well. And then, I install the DSP builder 10 without errors, but it seems that the installer did not setup the dsp components and classpath for Matlab. So, I try to setup manually following a thread in this forum.
>> cd /opt/altera/10.0/quartus/dsp_builder/bin/matlab/
>> setupDSPBuilderPath ('install', false, '/opt/altera/10.0/quartus/dsp_builder/bin', '/opt/altera/10.0/quartus/dsp_builder/bin/matlab/', '/opt/altera/10.0/quartus/dsp_builder/bin/mdllibrary')
Install type is install
Creating board components
Error executing : createSBlock('ComponentFactory', 'Stratix_III_EP3SL150_alteradspbuilder2', 'Stratix_III_EP3SL150:config', 'Stratix III 3SL150 FPGA Development Board ');
Previous command was : alt_dspbuilder_internal_new_system('Stratix_III_EP3SL150_alteradspbuilder2', 'Library');
Information on the last error:
Message: Error using ==> createSBlock at 46
Error due to multiple causes.
Failed at
createSBlock in /opt/altera/10.0/quartus/dsp_builder/bin/matlab/private/createSBlock.p at line 46
alt_dspbuilder_createComponentLibrary in /opt/altera/10.0/quartus/dsp_builder/bin/matlab/alt_dspbuilder_createComponentLibrary.p at line 28
setupDSPBuilderPath in /opt/altera/10.0/quartus/dsp_builder/bin/matlab/setupDSPBuilderPath.m at line 119
Please help me. Thank in advance.1 Reply
Problem is solved after hours of working hard. When installing the dsp builder, ignoring the Matlab setup. And the, open Matlab, setup the classpath and dsp block following the DSP installation from Altera.
I find out that we can run DSP builder 9.1, 10, 10sp1 with Quartus 10 and Matlab 2009a without errors.
