14 years agoDriving FPGA -> Host DMA with PCIe (hard IP in Cyclone IV)?
Hello all, I am trying to port an existing design which uses a PCI interface to a new board which uses the PCIe interface. Driving a DMA transfer on PCI was fairly simple, you write to t...
14 years ago --- Quote Start --- I'm sorry, I'm not sure about register inside of the core. But as I mentioned, you can use bar access to DMA status register directly and be able to read out its status. --- Quote End --- _Which_ DMA status register? I'm not using the DMA controller, my logic drives a DMA tansfer directly. This has to be able to read the DMA status but I can't see anything in the PCIe user guide about a 'finished the transfer' register. Nial.
