14 years agoDriving FPGA -> Host DMA with PCIe (hard IP in Cyclone IV)?
Hello all, I am trying to port an existing design which uses a PCI interface to a new board which uses the PCIe interface. Driving a DMA transfer on PCI was fairly simple, you write to t...
14 years ago --- Quote Start --- You should be able to do the exact same thing as PCI in PCIe. You can use bar access to read out the status of the DMA. or use interrupt. --- Quote End --- In the PCI core there's a Control Register at offset 0x306C, bit 5 of this tells you when the data you've written to the Tx port has been sent. I can't find any description in the PCIe User Guide of any similar register or mechanism. ? Nial.
