17 years agoDQ pins limitation of High Performance DDR2 Core
Hi, When I create a DDR2 Core of High Performance 8.0 which located on the top of the FPGA (StratixII EP2S30F672), and the data bus width is 32 (local bus width = 64, 4 dqs), error occured dur...
16 years agoThank you!
I want to instantiate the HP Core on the top of the FPGA device. The error I mentioned above is: Error: Delayctrlout port of DLL "ddr2:inst|ddr2_controller_phy:ddr2_controller_phy_inst|ddr2_phy:alt_mem_phy_inst|ddr2_phy_alt_mem_phy_sii:ddr2_phy_alt_mem_phy_sii_inst|ddr2_phy_alt_mem_phy_clk_reset_sii:clk|dll" feeds 4 DQS I/O pins that feed 32 DQ I/O pins. A maximum of 21 DQ I/O pins can be associated with single DLL. But, when I created another HP Core with the presets settings for Micron device (data bus = 72 and local bus = 144), the error above changed to "A maximum of 50 DQ I/O pins can be associated with single DLL." I am confused. If the maximum DQ I/O pins associated with single DLL is 50, why can't I instantiate a HP Core with 32 DQ I/O pins? Hope you to release me.:D :D
