11 years agoDPA Initial Phase in ALT_LVDS_RX core means what?
Hi all. I want to know that the setting about dpa_initial_phase (value:0 45 90 135 180 225 270 315 360) means the DPA circuit block will select a fixed shift phase(dpa_initial_phase) to sample ...
11 years agoI think if you knew the relationship between clock and data(many cases you don't), you could have it start in a selection that's correct. Maybe that reduces the DPA lock time? Not sure.
