15 years agoDoes the Triple Speed Ethernet IP Core support RMII
Hi everyone, i have a question concerning the Triple Speed Ethernet IP Core. Is it possible to connect the TSE MAC and the PHY with RMII interface? Because i found the TSE MAC isn't ...
12 years ago --- Quote Start --- Hi Guys, Im using a external phy Micrel KSZ8051 and Im having the same issue. Could anyone help me? The mii to rmii has worked? Im tryed it but I dont really have good results. I appreciate any help, Thanks in advance! Emanuela --- Quote End --- Have your problem solved?I have the same issue with you,could you help me?
