15 years agoDoes the Triple Speed Ethernet IP Core support RMII
Hi everyone, i have a question concerning the Triple Speed Ethernet IP Core. Is it possible to connect the TSE MAC and the PHY with RMII interface? Because i found the TSE MAC isn't ...
15 years agoThank you very much Cris72, i will try your code for converting both interfaces.
But somehow i made it now to transmit and receive raw ethernet packets with "Ostinato", but i have to check if the data being received is correct. I use the RGMII interface, which didn't work the whole time. Somehow strange. Thanks again herby
