mnazemi's avatar
mnazemi
7 years ago
Does Intel HLS Compiler combine or split variables?
Assume I have a component which includes something like the following lines:
bool input_0;
bool input_1;
bool input_2;
bool input_3;
bool wire_0;
bool wire_1;
bool output_0;
wire_0 = input_0 & input_1;
wire_1 = wire_0 & input_2;
ouput_0 = wire_1 & input_3;
The above code is effectively computing a four-input AND operation which is broken down to three two-input AND operations.
If the above code was written in Verilog, it would have been mapped to a single ALUT which takes all four inputs and calculates the output at one shot.
I was wondering if the same would happen if I ran the HLS Compiler flow. In other words, If I pass the above code to HLS and later to Quartus, does it allocate registers to wire_0 and wire_1 and compute them separately before generating the final output or will merge these into a four-input AND operation.
