12 years agoDoes changing the Simulink simulation options change the HDL code generation
Hello all, I am a DSP Builder starter and having read the DSP Builder Advanced Blockset manual I still have some questions. So is it so that the VHDL code generation is affected by changin...
12 years ago --- Quote Start --- Its only depent on the blocks, but you can only generate VHDL code from fixed step solver. --- Quote End --- I do not get this... How can it be only dependent on blocks but if i change the solver to variable step, no code is generated? So it is actually dependent. I opened an DSPBA example (motor control - ALU Folded) and the simulation settings is variable step. Also in the manual it is stated that for ALU folding I need a variable step (for simulation).
