15 years ago
DMA without nios
i am thinking that how to use a dma without nios.
it seems i shoud write a dma controller by myself.
does any one has done the same thing before?
or any one can provide me some examples?
thanks
    Do you mean you have a system without any CPU and need to transfer data to/from memory? What's the actual use of such a system?
    You can either write your own DMA, or create a component that's able to control the registers of an existing DMA.
    i just want to get datas form ssram throug dma,btw,that just is a homework.
    so, now i am thinking can i use spoc-builder to generate one.
    Yes SOPC builder is the way to go. But how will you put the data into your ssram in the first place?
    :)i just load a image into ssram(de2-70 board through panel-tool) , i want get datas out ,then i think of dma ,meantime i saw a paper in the internet,it uses this mather throug dma do the same thing and also shows a module image without source code (those in/outputs are belowe ) . but in the paper it seems the dma module is writed by hand and made by fifo megawizard ,so i wonder if i can make one by sopc builder , aha...:), just a weird idea .
    iCLK
    iFIFO_RST_n
    iRD1_FIFO_RD_CLK
    iRD1_FIFO_RD_REQ
    iRD2_FIFO_RD_CLK
    iRD2_FIFO_RD_REQ
    iRD3_FIFO_RD_CLK
    iRD3_FIFO_RD_REQ
    iRD4_FIFO_RD_CLK
    iRD4_FIFO_RD_REQ
    iRD5_FIFO_RD_CLK
    iRD5_FIFO_RD_REQ
    iRST_n
    iTRIGGER
    iWR1_FIFO_WR_CLK
    iWR1_FIFO_WR_REQ
    iWR1_FIFO_DATA_IN[31..0]
    iSSRAM_READDATA[31..0]
    oRD1_FIFO_RD_EMPTY
    oRD2_FIFO_RD_EMPTY
    oRD3_FIFO_RD_EMPTY
    oRD4_FIFO_RD_EMPTY
    oRD5_FIFO_RD_EMPTY
    oSSRAM_READ
    oSSRAM_WRITE
    oRD1_FIFO_DATA_OUT[31..0]
    oRD2_FIFO_DATA_OUT[31..0]
    oRD3_FIFO_DATA_OUT[31..0]
    oRD4_FIFO_DATA_OUT[31..0]
    oRD5_FIFO_DATA_OUT[31..0]
    oSSRAM_ADDRESS[18..0]
    oSSRAM_WRITEDATA[31..0]
    I don't know how the panel tool works, but you'll probably need a SOPC project with either a Nios CPU or a jtag-to-avalon debug module for it to access the SRAM. So in this case you'd better use SOPC builder and make a component with an Avalon master interface, to be able to share the SRAM between JTAG and your DMA.
    well.. this is a stupid question, but i wanna ask anyway..
    So you could actually create something using SOPC without implementing a NIOS 2 processor? I thought the whole purpose of using SOPC is to implement a design with a NIOS 2?
    Michael
    --- Quote Start ---
    --- Quote End ---
    Its not a stupid question. All the documentation relating to SOPC/Qsys generally talk about NIOS II systems. However, all you really need is an Avalon-MM bus master. The NIOS II just happens to be one type of master.
    I rarely use the NIOS II processor. I use the JTAG-to-Avalon-MM bridge for debugging, and then have other processor-to-Avalon-MM master designs for accessing components inside the FPGA.
    Cheers,
    Dave
    --- Quote Start ---
    Michael
    --- Quote End ---
    The next generation tool called "Qsys" was specifically named that to try to break the perception that you can't use SOPC Builder without Nios II. Nios II is a software core processor, SOPC Builder and Qsys are system integration tools. The only thing the SOPC Builder/Qsys have in common in common with Nios II is support for Avalon memory mapped interfaces.
