16 years agoDMA Transfer Issue
Hi, I have build a system which has NIOS II, DDR SDRAM controller, On-Chip RAM, UART,DMA Controller. My program memory is DDR SDRAM. I have connected DMA controller between DDR SDRAM and On-Chi...
16 years agonow i am a bit confused.
if your sdram is behind the bridge and that bridge is between nios and dma the nios and dma must have the same adress to gain access. so i wonder why you see your pattern at 00100000 instead of 02100000 could you post a screenshot of the sopc to see the connection between nios, dma bridge and sdram ?
