15 years agoDMA-controller doesn't generate an interrupt after changing the transaction type once
Hello, I realized that the dma-controller doesn't generate an interrupt the first time after I change the transaction type without resetting the core. But the transaction is done normally. ...
15 years agoI just had another Problem. The system froze. That happens because of an dma buffer overflow. This happend after a transfer type change.
So I think we can conclude the dma controller doesn't work like the user exspects after reading the user guide. Not changing the transfer type helps but is not always a solution. Resetting the dma controller works, too but reduces throughput and will not help if that's the bottleneck. So ALTERA, please fix this issue. Those error produce a lot of idle power. Regards, Frederik
