15 years agoDMA-controller doesn't generate an interrupt after changing the transaction type once
Hello, I realized that the dma-controller doesn't generate an interrupt the first time after I change the transaction type without resetting the core. But the transaction is done normally. ...
15 years agoI did further tests.
Debugging the status register after a timeout of five seconds (!) makes clear that the BUSY bit is still set. The length register reaches zero. Tha following transfer runs normally without any reset until I change the transfer type. But the first transfer doesn't finish after changing the transfer type. Can you confirm this? Regards, Frederik
