15 years agoDMA-controller doesn't generate an interrupt after changing the transaction type once
Hello, I realized that the dma-controller doesn't generate an interrupt the first time after I change the transaction type without resetting the core. But the transaction is done normally. ...
15 years agoWe made similar experiences, but with some differences.
In our case everything went well until we manually aborted the DMA-Transfer. It wasn't enough to clear the GO-Bit and reinit the DMA for a new transfer. To change the transaction type we had to do a core reset. but if the DMA-Transfer was successful, we didn't have to do a reset in order to change the transaction type. If I got you right, you always have to do a reset, don't you? Even after successfully completed DMA-Transfers? regards, Philipp
