WFitt
5 years agoDisplayPort Sink | 2 Pixel per Clock Video | Output not correct
I am using a DisplayPort IP core as sink, two 2.7 GB lanes, 1920 x 1080.
It works perfectly with 1 pixel per clock.
For a new project I need video data with even and odd pixels output
So ...
- 5 years ago
HI,
You can learn more about expected video data interface output from DP user guide doc (chapter 6.5.4, page 102)
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_displayport.pdf
- You may also want to monitor rxN_vid_valid signal assertion to detect the active video
Like wise you can also try generate DIsplayPort example design and monitor the vide traffic transaction.
dlim
Deshi_Intel
5 years agoHI,
dlim
WFitt
5 years agoHi!
Thank you for yor reply!
Finally, I found the cause of the issue with video data output in my DisplayPort top level module. A vector had the wrong size.
Wolfram
