Michael2021
5 years agoDisplayPort at non GPU mode on Cyclone 10 GX and Quartus pro 20.1
I tried to finalize design non GPU mode. doesn't provide non GPU mode example design. I can't figure it out how to connection Transceiver Native PHY Reconfiguration interface signal ( this signal i...
Deshi_Intel
5 years agoHi,
Transceiver reconfiguration process itself is a complicated process so I don't have easy way to explain to you.
- To learn more about it - you can refer to C10 GX transceiver PHY user guide doc (chapter 6) that I shared with you in earlier post
- To look at actual design implementation example, bitec_reconfig_alt_c10.v is the reconfig controller example design that do all the magic trick. It's that complicated as you can see in the design file itself.
- For DP design implementation, you only touch on Transceiver reconfiguration process during below 2 phases (I believed below operation are controlled by bitec_reconfig_alt_c10.v)
- During FPGA initial power up where you configure DP IP to operate at certain transceiver data rate
- Whenever there is a need to change transceiver data rate, for instance DP link training process
The reset controller IP that I mentioned to you is below design module in rx_phy_top.v
- gxb_rx_reset gxb_rx_reset_i (
- .reset (reset | dp_rx_xcvr_reset | rx_restart_100),
- You can signal_tap these 3 dependency reset OR signals to find out which one is causing the trouble and make necessary design changes
dlim
Michael2021
5 years agoHi
When C10GX FPGA is power-up,
Does the CLKUSR pin need to be stable clock for PreSICE function, before FPGA configuration complete ?
Michael
