10 years agoDHCP times out in ethernet example
I try to run the example "Nios II Ethernet Simple Socket Server on MAX 10 FPGA Development Kit". However, instead of "Acquired IP address via DHCP client for interface: et1¨ in step 7 o...
10 years agoThanks for your help. I finally solved the problem as follows:
- Disabling DHCP in the BSP - Giving the PC a fixed IP address I do not know why this works, although I can imagine that things get less complicated due to these measures. At least now it is fun to follow the simple communication with Wireshark.
