Sijith
2 years agoDebugging PCIe DMA transfer example design
Hi, I would like to have your continued support on this thread. Unfortunately this ticket got closed https://community.intel.com/t5/FPGA-Intellectual-Property/A-design-based-on-the-PCIe-DMA-transfe...
Sijith
2 years agoHi VenTing,
I ran the DMA read test and could not verify that we could read data that is being written to FIFO. Just a question, as the Signal Tap does not show the data flow to FIFO when it connects to the DMA design (as I mentioned in the last message) should be expect the DMA read to work?
I and currently I am trying to follow https://community.intel.com/t5/FPGA-Intellectual-Property/A-design-based-on-the-PCIe-DMA-transfer-example-design-for-Arria/m-p/1564164/highlight/true#M28507 and will update you.
Thank you
SE
