15 years agoDebugging Arria GX DDR2 Controller
I am using an ArriaGX EP1AGX90EF1152 to control 4 x MT47H128M16 SDRAM chips. The controller is the DDR2 SDRAM High Performance Controller v9.0 Build 235. Memory clock frequency i2 162MHz and PLL Ref ...
15 years ago --- Quote Start --- Hello, Did you use the Debug Toolkit for DDR2 and DDR3? Look at the "External Memory Interface Handbook Volume 4 Section III. Debugging" I used it to fix few boards. Good luck, Reuven --- Quote End --- Hi Reuven, Thanks for your help. I have not used the Debug Toolkit for DDR2 and DDR3, but I will try it as soon as I can get back to the production debug project. Regards, Brian
