13 years agodeadlock of chained dma based design on rmmod of Linux driver
I encountered the deadlock problem of chained dma based design when doing rmmod of Linux driver module. SignalTap shows that tx_sel_pcnt and tx_sel_slave signals (i.e. for altpcierd_rc_slave mo...
13 years agoIt turned out to be a driver issue.
Apparently, pci_disable_device() also disables bus mastering bit in pci config, which is enabled by default in Altera chaining DMA example. However, pci_enable_device() does not turned on bus mastering config bit, pci_set_master() should be called in the probe function, otherwise DMAs would not work.
