10 years agoDDR3 UniPHY issues Cyclone V
I'm using the UniPHY memory controller hard IP for a custom board using a Cyclone V. My design works on the BemicroCVA9 board from Arrow, however, on my custom board the external memory doesn't work at all. None of the calibration LEDs turn on (local_cal_success, local_init_done, local_cal_fail) or even the failure LED (local_cal_fail) doesn't go high indicating a failure (not sure about the logic behind this one). Also, when using the EMIF Toolkit and I "Link Project to Device" I get an error in the console window "Read request of 4 words was sent to the target but only 0 was returned". This is the error report: Anyone have any ideas? Thank you.
problem details Error: *** Fatal Error: Access Violation at 0X000007FECC9F1827 Module: quartus_sh.exe Stack Trace: 0x71826: emitt_systemconsole_unregister_tcl + 0x1bf46 (sld_emitt) 0x67aee: emitt_systemconsole_unregister_tcl + 0x1220e (sld_emitt) 0x67cad: emitt_systemconsole_unregister_tcl + 0x123cd (sld_emitt) 0x60da7: emitt_systemconsole_unregister_tcl + 0xb4c7 (sld_emitt) 0x161e2: TclNRRunCallbacks + 0x62 (tcl86) 0x17a65: TclEvalEx + 0xa65 (tcl86) 0xa6f8b: Tcl_FSEvalFileEx + 0x22b (tcl86) 0xa5646: Tcl_EvalFile + 0x36 (tcl86) 0x13982: qexe_evaluate_tcl_command + 0x582 (comp_qexe) 0x12aff: qexe_apply_ini_vars + 0x2a2f (comp_qexe) 0x17716: qexe_process_cmdline_arguments + 0x2606 (comp_qexe) 0x18601: qexe_standard_main + 0xc1 (comp_qexe) 0xcbe8: msg_initialize_out_of_memory_handler + 0x378 (CCL_MSG) 0xe31c: msg_set_stack_size + 0x7c (CCL_MSG) 0x4bac: mem_malloc_wrapper + 0x18c (ccl_mem) 0xc831: msg_exe_main + 0xa1 (CCL_MSG) 0x15a4c: BaseThreadInitThunk + 0xc (kernel32) 0x2b830: RtlUserThreadStart + 0x20 (ntdll) End-trace Executable: quartus_sh Comment: None system information Platform: windows64 OS name: Windows 7 OS version: 6.1 quartus ii information Address bits: 64 Version: 15.0.2 Build: 153 Edition: Full VersionNo RepliesBe the first to reply
