15 years agoDDR3: Can 1 controller control two memory chips
All, We currently use altmemphy with our own custom controller. We have succesfully used it many times but we want to now increase our memory interface width to increase bandwidth. We c...
15 years agoAddress command lines run at half the speed (2T) of the DQ lines. So speed issues shouldn't be important here.
Option 1 requires leveling which is not support in Arria II. Use balance tree topology on the PCB (split the addr/cmd signals on the PCB), you need to perform trace simulations first. (which at this speed you should do for any layout)
