16 years agoddr2 write/read problem
the control signals are came out correctly(read/write req, read/write data valid). but the read out data are not correct(compared with the witten data). I use the example_top (ddr2 hp v7.2) as the to...
16 years agoYou can't probe the DQ, DM, or DQS pins with signaltap. The best you can do is get into the datapath and look at the write and read registers just before they are latched to/from the I/O.
