16 years agoddr2 write/read problem
the control signals are came out correctly(read/write req, read/write data valid). but the read out data are not correct(compared with the witten data). I use the example_top (ddr2 hp v7.2) as the to...
16 years agoI got the same problem as you.
I use the ALT_DQDQS as the MEMORY interface , quartus encounter a internal error when assembler process if I probe the data output from ALT_DQDQS by SignalTapII. And I tried to use ALTMEMPHY megafunction ,but till now, it can't be simulated successfully, and it sames that the calibration process was unsuccessful. Is any somebody can help us??Thank you very much.
