16 years agoDDR2 without NIOS
Hello, in a project for my studies I am ask to get frames from vga port and to put them in a ddr ram: vert basic reading and writting in the memory. Is there an other simple way to use the...
16 years agoWell do you even need SoPC Builder? If you've only got one block that's going to interface to the DDR2 memory, you can just create the controller without SoPC
builder. If you do want to use SoPC Builder, you'll need to create your own Avalon Master component. In which case these would be helpful: http://www.altera.com/literature/manual/mnl_avalon_spec.pdf http://www.altera.com/literature/hb/qts/qts_qii5v4.pdf Jake
