14 years agoDDR2 with Uniphy Calibration
Hello, I'm trying to get a DDR2 interface up and running. The hardware seems to work fine when I use the EMIF toolkit. Calibration and margining tests pass with flying colors. Now when I...
14 years agoIf it's in the GUI then it is probably released. I would assume you want to use the Avalon-MM slave if you want another master like Nios II for example to access the CSR, otherwise I would stick to the JTAG version. If there are tools already available from Altera that access this CSR port then I assume they expect to see a JTAG interface (for now at least). The JTAG connections won't be easily traced, I won't go into the details why but take my word for it :)
