12 years agoDDR2 with Cyclone V
Have anyone been able to control a DDR2 SDRAM using the UniPHY Megacore IP from Cyclone V?? Im trying to do so, I have use this same memory with a Cyclone III before and im using the same circu...
11 years agoDid you tried to run RTL simulation using modelsim or any other simulation tool?
Check if the cal_successful signal is asserted or not.
