12 years agoDDR2 with Cyclone V
Have anyone been able to control a DDR2 SDRAM using the UniPHY Megacore IP from Cyclone V?? Im trying to do so, I have use this same memory with a Cyclone III before and im using the same circu...
11 years agoI reduced the speed interface to 200MHz, I can validate the timing, but the calibration still fails.
So that I can pass the calibration I've had to configure the "Advanced Clock Phase Control" parameter: "Additional Command And Clock Phase : 115 degrees". But then the timing analysis fails. Altera support answers was: Soft controller is not suppported for your speed grade 8 CycloneV (5CSEBA6U23C8). Very happy to know that at this step of the project...
