12 years agoDDR2 with Cyclone V
Have anyone been able to control a DDR2 SDRAM using the UniPHY Megacore IP from Cyclone V?? Im trying to do so, I have use this same memory with a Cyclone III before and im using the same circu...
11 years agoCan you try to reduce the interface speed for example from 400MHz to 200MHz?
And full compilation did you see any timing violation reported inside Quartus II?
