12 years agoDDR2 with Cyclone V
Have anyone been able to control a DDR2 SDRAM using the UniPHY Megacore IP from Cyclone V?? Im trying to do so, I have use this same memory with a Cyclone III before and im using the same circu...
12 years agoHelo,
Do you have our Cyclone V dev kit? Did you try to run the simulation first using the generated example design? Make sure the PHY calibration is passing as well as the user mode (read / write). After that you may jump into hardware testing and you may use the EMIF toolkit to check if your design is working. Hope this helps.
