13 years agoDDR2 vs DDR3 Throughput
Hi all, I have to update a board. The old design (Cyclone IV) used DDR2 Altmemphy running at 133MHz over 16 Bits. The new design (Arria V) will use DDR3 Uniphy with the Hard EMIF running a...
13 years agoYour arithmetic and theoretical numbers are correct.
I would put a design together with correct timing constraints and make sure that your DDR3 will actually run at 533 MHz and meet timing. You might also want to get an Arria V devkit and try to run your design on it.
