17 years ago
DDR2 SODIMM Verification + probing solutions
Hi all,
I hope I don't get shouted at for posting a verification thread on this forum - sorry if there's a more appropriate forum but I thought some of you here may have been through this already.
Do any of you have any experience of using Tek logic analysers and Nexus interposers? As they say probing at the SODIMM fingers with an interposer is not the ideal position to probe.
I had Mentor's HyperLynx hired for a while to check out our design (pre-layout) - a quick peek at the signals at the SODIMM fingers showed some ugly signals at this point while everything is good ar the DRAM balls where it's supposed to be.
Any feedback greatly appreciated as I need to make some decisions very soon about what proing solution to go with.
Stephen.
    Yes do not run the DDR2 traces over a plane split. You may have to increase your layer count to make this happen.
    Jake
    One more thing from your last post Jake - if you don't have access to a fairly fast scope, Logic analyser etc how do you verify/gain confidence that everything's as it should be and you have some margin?
    Will your design ship in quantity?
    Stephen.
    Jake - would you be willing to pm me with your stack-up?? My design is a two SODIMM design also.
    Just thought to ask. thanks again for your replies - very helpful.
    Stephen
    We do have a few scopes that have adequate speed, but no probes to go with them. I know you're thinking that doesn't make any sense. We design video broadcast equipment so we can do 95% of what we need to without a scope probe.
    Our primary concern on the board are multi-gigabit serial links so the memory becomes somewhat of an afterthought.
    Our quantities may be fairly low compared to yours. However, we run all of our assembled boards through a complete memory test at the assembly house so we have a high level of confidence they will work properly.
    I may be able to send you the stackup. What is your board's layer count? What dielectric are you planning on using?
    Jake
    We're in the process of completeing it right now - its 14 layer in FR4
    Stephen
    I think I've replied - my sent number is still 0 - did it arrive Jake - pm me back if my response is insufficientlet.
    Stephen
