13 years agoDDR2 SDRAM with UniPHY not generating half_rate_clock
Hi there, I'm using Quartus 12.1 SP1 and generated a DDR2 SDRAM Controller with UniPHY via the MegaWizard Plugin Manager. The Memory Frequency is 400 MHz, PLL reference clock 50 MHz and the Rate...
13 years agoYou can refer to the workaround for this issue:
Problems with simulation of DDR2 SDRAM Controller with UniPHY http://www.alteraforum.com/forum/showthread.php?t=38337
