17 years agoDDR2 SDRAM: local_init_done not going high
I have built a DDR2 SDRAM v7.2 controlller, v7.2, using the Megawizard and a native interface. I have reviewed my schematic and pinout and it looks to be correct. The local_init_done is not going h...
17 years agoThanks FvM.
My SODIMM has 64 bits. What mode should I use, x8/x9, x16,x18, x32,x36, x4, or x4 Mode? I have a Stratix II 1020 -3 FPGA. I'm looking at the Pin Information for Stratix II EP2s60 devide and it is confusing because it has DG group for DQs mode and the DQ group for non-DQS mode. I'll assume that since my Micron SODIMM module uses the DQS pins (non-differential), that I need to use the DQ group for DQS mode pins. Thanks for all of your continued support.
