17 years agoDDR2 SDRAM: local_init_done not going high
I have built a DDR2 SDRAM v7.2 controlller, v7.2, using the Megawizard and a native interface. I have reviewed my schematic and pinout and it looks to be correct. The local_init_done is not going h...
17 years agoDDIO pins? Should I only be using certain pins? Do I need to instantiate DDIO between the DDR2 signals and the output pins...Sorry for the question...I'm really confused now. I know from memory(i'm at home and don't have access to my schematic) that I am using the pins on the bottom of the chip(AB-AJ), and I think mos of them are 1-20 as well. Thanks for help...I will look into this more tomorrow at work.
