14 years agoDDR2 SDRAM Controller with ALTMEMPHY Synthesis error
I am trying to generate a DDR2 SDRAM Controller for a single 128 MB DDR2 chip. QSYS perform a good generation (6 warning wich don't concern the ddr2 Controller) but when i try to synthesis the project i have this error : Error: Output port DATAOUT of DDIO_OUT primitive "nios2_ca1_sys:nios2_sys_inst|nios2_ca1_sys_ddr2:ddr2|nios2_ca1_sys_ddr2_controller_phy:nios2_ca1_sys_ddr2_controller_phy_inst|nios2_ca1_sys_ddr2_phy:nios2_ca1_sys_ddr2_phy_inst|nios2_ca1_sys_ddr2_phy_alt_mem_phy:nios2_ca1_sys_ddr2_phy_alt_mem_phy_inst|nios2_ca1_sys_ddr2_phy_alt_mem_phy_clk_reset:clk|altddio_bidir:DDR_CLK_OUT[0].ddr_clk_out_p|ddio_bidir_n5h:auto_generated|ddio_outa[0]" must drive input port I of an I/O OBUF primitive I suspect it to be a reset problem of the controller because, before this error i have those warnings : Warning: The following bidir pins have no drivers Warning: Bidir "Ddr2_Clk_P[0]" has no driver Warning: Bidir "Ddr2_Clk_N[0]" has no driver Warning: Output pins are stuck at VCC or GND Warning (13410): Pin "Ddr2_Cke[0]" is stuck at GND Warning (13410): Pin "Ddr2_Cs_N[0]" is stuck at GND Warning (13410): Pin "Ddr2_Odt[0]" is stuck at GND In QSYS i have connected soft_reset_n and global_reset_n inputs of the ddr2 Controller to the clk_reset ouput of the Clock source (wich also drive the reset_n input of the Nios2). I am stuck with this error, have i tried many reset configurations, but i still have this error...Is it realy a reset problem? Need Help Please.
