17 years agoDDR2 reading errors on last two words
Hi, I've some problems with my ddr2 design. I use Altera DDR2 high performance IP on pci express dev board (Stratix II GX). I build some logic around my memory controler in order to test...
17 years agoIf you don't get timing errors related to SignalTap, you can basically trust it's results. As far as I understand, SignalTap shpws read faults as the missing pnf output does. If it occurs at accidental positions in the test, it's most likely a signal quality or timing issue. If we can assume, that the Dev. Board hardware is O.K., it must be related to your settings.
