17 years agoDDR2 reading errors on last two words
Hi, I've some problems with my ddr2 design. I use Altera DDR2 high performance IP on pci express dev board (Stratix II GX). I build some logic around my memory controler in order to test...
17 years agoDid you also try with the Altera provided test driver for DDR2 HP core? Just to assure, that it isn't a problem of wrong interface handling? In case of signal quality issues, you rather get accidental faults at different locations because of the pseudo random data used by the test driver.
