14 years agoDDR2 on two sides - one controller
Hello, We are using an Arria II with DDR2 chips on two sides of the FPGA. Is there a way to aggregate the two and control them with one instance of the DDR2 HP controller? We are using HP and...
14 years agoAs the commands for the two chips are are issued by one controller each DRAM chip will run in sync with the other. The Altmem-PHY just sees the two chips as an aggregated DQ/DQS bus.
